moro
tommonen ilmestyi mitäs tämä nyt tarkoittaa.
VAG-COM Version: Release 311.2-N
Control Module Part Number: 4B0 906 018 CG
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 11551
Work Shop Code: WSC 76244
Additional Info: WVWZZZ3BZ1E183205 VWZ7Z0A3417917
1 Fault Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
vika valo palaa
Eipä ole tullut vastaan mutta listasta poimittua:
* Check Mass Air Flow (MAF) Sensor
* Check Fuel Pressure Regulator
* Check Fuel Pump
* Check Intake/Exhaust System for Leaks
* Check Secondary Air Injection for Leaks
* Check Vacuum Lines for Leaks
* Check Fuel Pump
Vw New Beetle 2.0 -99
Vw Golf Variant 1.4TSI -14
Yamaha XV1100 -98
Yamaha XV1100 -98
