Thursday,23,May,2013,17:00:52:47442
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ1E232317 Mileage: 335330km/208364miles
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 3B1 907 401 B
Component: 2.5l/4VTEDC G200SG D01
Coding: 03012
Shop #: WSC 76500
VCID: 1D3BC2B997089CF02AA
Subsystem 1 - Part No: 00009059
Component: 130 106BC062_2.V70491432181
WVWZZZ3BZ1E232317 VWZ7Z0A3504183
1 Fault Found:
01318 - Control Module for Injection Pump (J399)
49-10 - No Communications - Intermittent
Readiness: N/A
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 C
Component: 08 AIRBAG VW6 04 0004
Coding: 12344
Shop #: WSC 05311
VCID: 3777301115F4D6A0D06
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 845 A
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 21115
Shop #: WSC 19411
VCID: 2241F145AE76A308178
1 Fault Found:
00462 - Control Module for Seat Memory; Rear (J522)
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05314
VCID: F0E54B0DB01AC19851C
3 Faults Found:
01333 - Door Control Module; Rear Left (J388)
00463 - Control Module for Digital Sound Package (J525)
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 0G Komfortgerát HLO 0002
Coding: 00259
Shop #: WSC 05311
VCID: 36693D1512FE2FA8CB0
Subsystem 1 - Part No: 1C1959801
Component: 0G Tõrsteuer.FS 0001
Subsystem 2 - Part No: 1C1959802
Component: 0G Tõrsteuer.BF 0001
Subsystem 3 - Part No: 1C0959811
Component: 0G Tõrsteuer.HL 0001
Subsystem 4 - Part No: 1C0959812
Component: 0G Tõrsteuer.HR 0001
3 Faults Found:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
00931 - Locking Module for Central Locking; Rear Right (F223)
27-00 - Implausible Signal
End ---------------------------------------------------------------------
Että mikä helevetti on tuo Control Module for Seat Memory; Rear (J522)??
Tankista on tutkittu pumppuja(?) ja mitään surinoita ei kuulu..
Osaako kukaa sanoa noista mitää??
E: Turhia kohtia poisteltu.
